| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2023 Posts: 23 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 23 | An old thread, but a new problem. I'm missing something here. Have a 46 Chevy. Problem is the horn wire from the steering wheel. Horn when I bot it was activated by a button strapped on the outside of the steering mast. toss that. Has a wire coming out of bottom of the steering mast, already cut off and not connected to anything. I understand the circuitry grounding and all. I got the horn button assembly, spring etc, and steering wheel off Was a bell shaped spacer between the steering wheel and the steering mast, got that off. Bearing was there, spline shaft, no horn wire. So I guess the horn wire is attached to the back of that bearing. What I don't understand is how pushing the horn button grounds anything. Seems to me that the bearing (to which I think the wire is attached), thru the steering shaft, thru the steering gear is already grounded. So it looks to me like the wire (and bearing) is grounded all the time, which can't be. What am I missing?
Jim "You can observe a lot by just watching" Y. Berra 46 Chevy Pickup 76 White Freightliner | | | | | Joined: May 2015 Posts: 11,159 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,159 | The bearing is insulated from the mast and the steering shaft. The steering wheel should have a plunger that rides on the bearing (that’s connected to the horn wire. When you mash the horn button it makes contact with the plunger and provides a ground path through the steering shaft.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | I may not familiar with '46 horn parts. I expect them to be similar to '47.2 through '55.1. Can you attach pictures of all of your horn parts?
| | | | | Joined: Jan 2022 Posts: 2,492 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,492 | Not the same as 47-55.1. Chevs of the 40s has some parts, but I'm not familiar with the parts to know what you might need.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: May 2015 Posts: 11,159 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,159 | The Art Deco period trucks may not be the same as the 47-54 that I described, but the principle should be the same. The horn wire should be insulated from any ground until the horn button is pushed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | that wire that is coming out the bottom get you meter out and see if you have connectivity from the outer top of bearing under steering wheel to that wire. if not the wire is loose and you need to pull the bearing and reattach. You should not have connectivity on that wire to ground without the button pressed.
check for connectivity from the outer top of the bearing to ground or clean part of steering shaft outside cover there should be none and none to the steering shaft itself. if you do the insulation is bad on the bearing | | | | | Joined: Jul 2023 Posts: 23 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 23 | Great. Heigh-Ho, and off to work I go. Report later. Thanx.
Jim "You can observe a lot by just watching" Y. Berra 46 Chevy Pickup 76 White Freightliner | | | | | Joined: Jul 2023 Posts: 23 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 23 | It appears that the previous HA restorer got a new horn button assembly and it didn't quite fit right. Basically stuck grounded when you pushed it. Evidently they didn't know how to tweak it so it would work. So to have a horn they put a button on the side of the steering shaft. Once disassembled, some judicious filing got it working fine. And the ground wire down the steering shaft seems good. So I now have a good working horn in the center of the steering wheel where it should be.
Thanks for the enlightenment.
Jim "You can observe a lot by just watching" Y. Berra 46 Chevy Pickup 76 White Freightliner | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I had issues with my 54, the steering wheel was one of those very expensive ones but after a while when you turned a corner it beeped. worked and worked on it but finally put a button under the dash, I wish I had put it on the steering column. Thought many times to move it.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2023 Posts: 23 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 23 | If you saw the movie "Little miss sunshine" you could fit right in there. Driving along with an occasional honk. But not appreciated when pulled over by a cop.
