| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Never use expensive (synthetic) oil with a cartridge filter.
Changed the oil twice on the fire truck today...
:mad: :mad: :mad: :mad:
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | John,
Does this mean you didn't get the canister back on properly and all the oil poured out.
Stuart | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | Hi John, I put a synthetic blend in our old truck and have driven it ,it seem's ok but how could i tell for sure? Thanks Chad | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Stuart -- That's precisely what that meant Chad -- I don't really know. I'm using synthetic because I can (I have easy access to it and all my other vehicles are using it) and I only plan on changing the oil once a year. Other than that, just check your dipstick and see if it stays cleaner longer? Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | The second car I owned was a '67 Chevelle with a 283, it had a canister type. The very first time that I changed the oil, the rubber seal slipped down before I got the canister tightened up to it. You should have seen the mess. It's been about 30 years since that happened, but if I remember correctly, after that incident I think I would put 3 dabs of grease on the seal to hold it in place. No better way to learn than the hard way, right John? I bet you never do that again. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | John, Judging from past experience, I believe I am quite capable of doing it again...
The grease is a good idea. One of the old timers here told me to put some wheel bearing grease on it (probably same as you). Worked pretty well.
The other trick was making sure the cannister didn't get canted. Now this may all sound elementary to you guys but ole John is just figuring out some of this stuff for himself -- apparently there is a spring in the bottom of the cannister that keeps the filter tight against the engine to make a tight seal? Well that darn spring makes it hard to hold the cannister firmly and squarely --- and if you just let it hang by the bolt and tighten it up, it gets canted or knocks the ring out at the top.
And there wasn't exactly a whole lot of room to work under there, either. Which surprised me.
And who's idea was it to run the exhaust pipe two inches from the oil filter??? I thought one of the jobs of the oil was to help with cooling? Kinda defeats the purpose having the exhaust line pumping heat into the oil filter housing (the side of the cannister facing the exhaust line doesn't have any paint on it from the heat...)
GMC a superior truck?? So far I am not impressed.
:p John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Enjoyed a laugh at your expense John. My dad taught me how to do that job 50+years ago. :p | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | Thank's John ,I checked it after putting a good weekend of driving on it and it seem's a.o.k.Not to plug anything but a friend turned me on to being a prefered customer to amsoil.It is the only oil that i have found that let's you go 25,ooo mile's between oil changes.Everything i own with a motor has synthetic.About 12,5oo i put on a new filter and a fresh quart of oil.So far with the cold weather in IOWA it saves on the batteries and starters.With the synthetic blend i used in the old truck it sure seem's to purr right down the road.Have a good summer and thank's again,Chad. | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Gaz -- My work here is done Chad -- that Preferred Customer stuff is the way to go! I run Amsoil in everything I have -- Pumps to Stovebolts to modern drivers. Regards, John
