0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 56 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 56 | i have a 1952 gmc truck. it was positive ground and switched it to negative ground. two thigs i need help with rather then lift carpet so i can access battery through floor. to hook up charger can i not hook positive lead to starter positive and ground lead to any ground. second question i just tried heater for first time sense i swithed to negative gound. will blower turn in correct direction or do leads to motor have to be switched. it seems to blow ok but i wonder lol. thankyou for your help
| | | | | Joined: Oct 2021 Posts: 6,964 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,964 | Yes, that'\s how I have done it for 3 years.
Your heater fan may be spinning in the opposite direction now but if heat's coming out, who cares?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Only permanent magnet motors reverse direction when the polarity is changed. Your heater blower will continue to turn the same direction regardless of polarity. Ditto for the starter. You will need to repolarize the generator. Jerry
| | | | | Joined: Jan 2022 Posts: 2,499 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,499 | Just curious Mike: Why did you switch to a negative ground?
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | When I put a 6-volt heater in my 54 which had been converted to 12 volts it would run on high but not on lower settings, it would hardly turn. I don't know if it was 12 volts,s to begin with, late 54 build. I found the heater in a junkyard in 1984, when I was young and ignorant. Now I am old and ignorant. My truck came from southern Indiana and heaters were an option back then.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2011 Posts: 56 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 56 | hello bill. i had no real reason to switch to negative ground excepte for simple reason im use to it. i read on your profile you ahd one truck with a 228 . my truck history. my uncle bought it new in cailfornia. it had 228 engine in it.when i bought truck from my aunt afetr my uncle passed it had 51000 miles most of it life was in bullhead city. and he pulled a 30 spartan trailer with it(we would never get away with that today ). they took a trip to alaska pulling that trailer . sense then it was used locally to pul trailer. from serial number it was assembled in san frrancisco. i might be wrong with that. i brought it up to canada andsecond winter i goofed up and froze block. then spent a cpl yaers when free time to find a 228. grand kids came along and truck sat in my garage 27 years.when i turned 71 i told wife i need to get on road as im getting to old. quest resumed to find 228 found two one in portland it was cracked and one in sask whick also was cracked. by fluk i found a 235toatlly redone bought it . when install it i found out a chev 235 is shorter . so made a new mount for front leaving cross member original. then decided on negative gound . for no real reason. im 74 now and truck has 57000 miles love it and think of my aunt and uncle every time i drive it now i wish i had converted to 12 volts as i want a radio as seems 12 are more comon.it came with 15 inche split rims and now converting to solid rims. looking at this letter i got carried away . | | |
