4 members (Robert Crandall, mick53, Danielbolt, 1 invisible), 165 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#1528945 12/09/2023 1:27 AM
Moderated
Moderated
Hey Folks !
I need to find some brake shoe return springs for the rear of my 51, 6400.
Does anyone know of a cross reference part or source for
originals ?
Thanks !
Big Bolt Forum Co-moderator
1948 Chevy 2-Ton
Moderated
Moderated
Thanks believe that one is for the front.
I need the rear springs. They are short fat ones.
I’ve been trying springs off other trucks from the parts store
but can’t find anything strong enough.
Group 5.026 Brake Shoe Spring,
1951-57 1-1/2 & 2 ton, pull back, short, rear shoe (3-7/16" O.L. free)....p/n 3694516
1951-57 1-1/2 & 2 ton, pull back, long, rear shoe (3-7/8" O.L. free)....p/n 3694799
Place an ad in the Parts Wanted section, I think we had a member that had a batch made a couple years ago, maybe he still has a few. Or maybe someone has a couple used ones.
You need 4 of each to do the complete rear axle.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
V
VEW Offline
V Offline
Boise- did you find your springs?
I had some made when I did the brakes on my 59 1-1/2 ton several years ago.
Still have some if you need them.
Mike. You say to 57, but wouldn’t 58/59 be the same?
~ Victor
1957 3100 - moved on
I always thought they were the same, but I just checked 6 different year parts books and the all end at '57. maybe it's a typo that never got fixed... ohwell
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
2 Offline
I could sure use a set if you have enough, if you will please pm me and we'll figure it out from there. Thanks
1956 Chevy 6100 with a dump box
Story in Big Bolts
1949 ford 8n tractor
1958 861 diesel ford tractor
2003 honda vtx 1800 c bike
V
VEW Offline
V Offline
Give me a minute-or two- and I’ll post the specs so we know what we’re talking about-or at least going through the motions 🤓
~ Victor
V
VEW Offline
V Offline
So, this is what I have, and only have 3 new ones left (and the 4 I removed from magic bus).
I’ll try to find the place that made them and post it again. I know it’s been a while since the last time I did.
Old one on left and new one on right.
~ Victor
I just checked the GMC parts book. Same thing where these parts are used on 55.2-57, but not 58-9.
The "TXY" are years 57, 56 and 55.2. The "4" is how many. The "22M, H110" and so on are the various axles these brakes were used on, followed by a description.
V
VEW Offline
V Offline
I sent my old spring to Timac and they asked how many I wanted. I ordered 10: used 4, gave 3 away and have the remaining 3 if someone wants them.
It’s been over a decade, but here is the info I have.
~ Victor
Victor,
Thanks for posting a picture of the 1958/59 rear brake pull back springs. This confirms they are different than the 1951/57 springs, see attached pictures of springs I took off of a 1956 4400.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
V
VEW Offline
V Offline
Thanks Mike. All good to know.
But if someone can’t find a spring, I recommend checking out Timac.
~ Victor
2 Offline
Mike and Victor, Thank you both for the pictures and information I just measured mine and I can see that whoever was into the rear brakes ( which are new ) put the short springs both on top shoe and the longer ones both on the bottom shoe. So mystery is solved, Victor thaanks for the information on who made yours I'll look into that thumbs_up .
Pic of my long ones, it would be nice to have some new spares .
Story in Big Bolts
Thought I'd add this picture from the 1955-2 Shop Manual to aid anyone that wonders where the springs go...
The Long (black) springs go at 1:00 and 7:00 o'clock.
The Short (green) springs go at 4:00 and 10:00 o'clock.
Hope this helps,
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
