1 members (baldeagle), 42 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#1528922 12/08/2023 11:36 PM
I have power steering on a 1954 3100 and I was wondering if the power steering should be topped off periodically, or replaced? I have mentioned here a steering feel change lately. I put on new tires and there is a difference in the feel.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
It *shouldn't* need topped off. If there is a leak (which many have) it will need topped off occasionally and that usually isn't a big deal.
On later model (80s-ish) systems, the power steering fluid change interval is usually in the 60k mile range. Not sure what you have installed.
That said, bad power steering fluid would not cause the issues you have been describing. That very much sounds like a mechanical problem.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
if its the cpp power steering.
I have had issues with the fittings starting to leak on the powersteering box itself.
Because of its location to the engine even with a heat shield I think the heating hot and cooling loosens the adapters and fitting.
I have to tight them at least once a year. I can always tell because the fluid starts getting low.
I don't think I have ever had to top off the others i drive but at least once or twice in 10 years.
So check for a small leak.
I do the paper towel test around the fittings.
Drive for a while then see which one has fluid.
zipties / tape keep them in place.
I had an issue with the fitting on the back of the post-80s steering pump and an earlier model high pressure hose. It threads in fine and feels tight, but ended up leaking over time. The old hose is inverted flare, while the pump is supposed to take an o-ring type fitting.
They sell an adapter to make it all work. All is good now.
