2 members (crenwelge, ndkid275),
118
Mod | | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 95 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 95 | I`ve been trying to remove the rusted bolt that secures the window divider bar inside the door on my 53 3100 PU. Due to its location, moisture has run down the bar and frozen the bolt with rust. I have soaked the bolt with PB Barnum oil, used heat from a mini torch and still no movement. Access makes this a tricky job. My socket (1/2 inch ) pops off when I apply torque as the sheet metal support inside the door is flexy compared to the frozen bolt. Anyone out there that can offer a suggestion I`m ALL ears!
1953 3100 Pu
| | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | I would keep trying heat and soaking with penetrating oil. I don't know if the Dewalt 1/4 inch impact driver I have will fit thru the opening, but that might get it loose by alternating tightening a touch and then loosening with the impact driver.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2019 Posts: 95 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 95 | I was able to snake my impact driver into the door and Bingo the impact did the trick. Thanks so much for the help!!
1953 3100 Pu
| | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | Awesome! Thanks for the feedback on what worked.
