0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | Tore apart and cleaned out the dirt and painted the starter so it is pretty. the oilable end bushing and brushes look decent. but the flywheel side bushing is worn egged on one side and pretty sloppy so I went into NAPA to see if I could get lucky. He said they were the same for decades with only one choice, ordered it and it isn't even close. From measuring the shaft and casting I figure the bushing should be around a .515-.52 ID and .61-.615 OD. the Part number 4200 they sold me is about a .51 OD. (even smaller than the actual shaft) The old bushing I pulled out was made with a split and kind of like ears on the end to retain it in place. The starter appears to be like the pictures of being correct as the foot stomp was changed a few years later, so I think it is original. Suggestions?
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Jan 2022 Posts: 2,440 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,440 | Chevs of the 40s lists this part as correct for the starter drive end bushing of MOST 29-37 Chevy cars and trucks.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | Thanks Bill, spoke with sales at chevof 40's and apparently there are early and late sizes and they have both. problem is shipping on a 2.50 part so I'll try to put together a small order to spread that cost a little or try a different FLAPS
| | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | A few years back I got bushings from a Napa here in Canada that is amazing.Opps just read the rest disregard.
