3 members (Shade Baby, tclederman, dt235sd), 101 guests, and 3 robots.
Topics128,266
Posts1,058,139
Members48,482
24601
24601
The latest from Jon G -- The Ernest Hemingway of engine Tech Tips!! Jon shows how to make some spreaders to seal your valve cover and stop those annoying leaks!
The Tech Tip is posted HERE
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Very nice!
Jon’s solution is likely more effective and better looking than my theorized solution. On my “when I get around to it” list is to grind some width out of the widely available SBC valve cover spreaders. I think they could be made to fit.
This is the kind of thing I’m talking about:
https://www.autozone.com/external-e...alve-cover-load-spreader-5321/228340_0_0
What little oil seeps from my valve cover is it noticeable enough given the seeps from other areas. Based on advice given here, I have done “part” of the tech tip. The tinsmith work to flatten the bolt holes and my VC is glued to the head with Permatex super 300.
1951 3100
Great idea, but I'm curious as to why these are made from aluminum rather than steel?
1965 Chevy C10 Longbed Fleetside
Here's enough spreader bars for two engines- - - - -might need a little tweaking with a bench grinder to make them fit a stovebolt six- - - - -
www.ebay.com/itm/192972613053?
Moderator, Electrical Bay
Thanks! I had aluminum handy and it cuts okay with a saber saw. Besides aluminum that thick will provide enough "springiness" and I wanted pressure extending all the way down the sides and to the back and front corners. This was done a while ago and leaks haven't been a problem since.
~ Jon
I see. Thank you for the tip. I will definitely fabricate some for my new engine. Hate to have a newly painted engine and then have oil leaking on it
