3 members (Peggy M, Cletus1950, Charles in CA), 134 guests, and 5 robots.
Topics128,106
Posts1,056,217
Members48,436
#1527616 11/27/2023 10:11 PM
My chev rad part number 3122375 will R-214 A 49 H
Problem is it does not properly fit my chev rad support.with cutting out the x braces and cutting off the lower rad support cross member I was able to get it in. But I am wondering if I have a gmc rad or a different year?
Rad 3122375
Original
The third picture is a GMC radiator. Cap is on a 90 degree filler tube. Chevies I've seen had the filler on top of the upper tank.
Thanks Bill . That would explain why all my problems. But given how much I spent on the re-core I will have to put it back in the way I took it out(that’s the third picture) There might be a way for me to re-enforce the bottom cross member that I cut out
