0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | What is the correct carb for a 1960 261? I’m starting to look and want to ensure I get the correct one.
Chris | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Thank you! I know my 216 Rochester B isn’t getting enough fuel due to jet size. I don’t want that to happen to the 261 when I rebuild it.
Chris
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I just went through this carb issue on my newly rebuilt 261. I was using an old 216 Rochester. GM had major recall/warranty problems with those Rochester B's back in the 50's when they decided to not use Carter carburetors anymore.
I ended up going with a Zenith 228 model 11963. If you do this, the hard part will be finding a "175" base that fits the 2 15/16" intake manifold hole spacing. It was meant for a GMC 270 motor, which is awfully close to a 261. Much better quality carb than a Rochester from what I have learned.
I also had a Carter YF for a 258 AMC engine recommended as well, since a 258 is so close in size to a 261. That would have been my next option if I hadn't found a good Zenith core to rebuild.
After getting help setting the timing on my 261, it runs wonderfully. Smooth 500 rpm low idle and full power up to wide open throttle. Fast start-ups. For now, it is running like it was intended to.
PM me if you want pictures and details.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Those Zenith 175 bases are worth keeping - | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | When talking about the 1960 optional 261 you are beginning to travel down the river stix (spelling, don't believe that stuff). the optional 261 in 1960 had for both the automatic and standard shift a #57 metering jet. In my opinion the 57 is a good all round metering jet. Unless you have a 261 from a bus that was governor equipped from factory then you need a #42 jet. This is a Rochester BC carb. If there is any evidence of a governor attached throw it away and go with your exiting BC. Most governor's at the time kept the speed at 45 mph. I'm a Rochester/Carter Nazi so you may need advice from tclederman or hotrodlincoln. There is a gold mine of folks on this web-site that have pretty much seen it all. A plane old Model "B" with a choke pull off is my preference on all the oldies. Stuck in my ways Doc.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I'm running the correct carb for my 261, engine was a 62 casting, it came with its original carb and it is a Rochester B with a 64 metering jet. Engine was out of 1-1/2 ton truck. Now I do remember my 235 with a rochester B had a smaller venturi with a smaller jet believe a 58
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Thanks! I know my 216 carb won’t fit, so looks like I will be looking for one to rebuild!
Chris | | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I replaced the Rochester B on my 1960 261 with a 32/36 progressive 2 barrel carb from Tom Langdon & love it.
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Nov 2002 Posts: 2,764 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,764 | Tim - someone far wiser than I once said something to the effect: "if you haven't tasted steak, lunchmeat is great!"  Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On my 1960 261 is a 2-barrel AA1 Zenith (from a GMC 302).
It has variable/adjustable jets added by me (added by my carburetor rebuilder, actually).
It has run flawlessly and economically for over 10+ years. | | | | | Joined: Feb 2019 Posts: 4,475 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,475 | Tim, you do realize you posted on a three year old thread!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Phil
Yes, I knew - that carb info might help someone searching old threads for information.
If you are a moderator and you think my post should be deleted, please delete it | | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Not my Forum to Moderate but..
I think adding new info to an old post is beneficial for those doing "research".
With only 31,856 posts, I think you you need to "up your game" and continue to help the rest of us with your experience and knowledge. ( humorous sarcasm )
I've only "been around" since 2014 and recall the many times you responded to posts with helpful information and guidance.
Thanks Tim, we appreciate you!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Apr 2004 Posts: 5,072 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,072 | Agree, on all counts. Tim, you are a great source of information and always very willing to share. (And you do good links.  ) Thanks for all that and more.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Feb 2019 Posts: 4,475 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,475 | I also agree, Tim has been a mainstay on this ship we call “Stovebolt” for many years now. The top #1 poster on this forum. Always offering good advice and good information. Thanks Tim for all you’ve done to support our hobby. Since number two is OK with this thread, I see no reason to delete anything.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the positive comments.
I posted this to help future readers/members.
I have always used Chevrolet Truck Data Books (TDBs) as sources of information/identification about Chevrolet Trucks, even though the TDB has not in the past been enough (here) to allow some TDB vehicles to be called a truck. | | |
