4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#1366774 06/28/2020 3:44 AM
What is the correct carb for a 1960 261? I’m starting to look and want to ensure I get the correct one.
Chris
ndkid275 #1366786 06/28/2020 9:59 AM
I think it is Rochester 70015140 (1959 USA) or Rochester 7015013 (1960 Canadian).
The 1959 specifications for that carburetor are listed here.
The 1960 specifications for that carburetor are listed here.
I'll try to remember to look in the USA 1960 Shop Manual (stored in my garage).
ndkid275 #1366810 06/28/2020 1:42 PM
Thank you! I know my 216 Rochester B isn’t getting enough fuel due to jet size. I don’t want that to happen to the 261 when I rebuild it.
Chris
ndkid275 #1366824 06/28/2020 3:09 PM
Take out the jet.
Better?
ndkid275 #1366834 06/28/2020 5:26 PM
I just went through this carb issue on my newly rebuilt 261. I was using an old 216 Rochester. GM had major recall/warranty problems with those Rochester B's back in the 50's when they decided to not use Carter carburetors anymore.
I ended up going with a Zenith 228 model 11963. If you do this, the hard part will be finding a "175" base that fits the 2 15/16" intake manifold hole spacing. It was meant for a GMC 270 motor, which is awfully close to a 261. Much better quality carb than a Rochester from what I have learned.
I also had a Carter YF for a 258 AMC engine recommended as well, since a 258 is so close in size to a 261. That would have been my next option if I hadn't found a good Zenith core to rebuild.
After getting help setting the timing on my 261, it runs wonderfully. Smooth 500 rpm low idle and full power up to wide open throttle. Fast start-ups. For now, it is running like it was intended to.
PM me if you want pictures and details.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
ndkid275 #1366836 06/28/2020 5:37 PM
Those Zenith 175 bases are worth keeping -
1946 GMC Project
"Back-in-the-day Restore"
ndkid275 #1367041 06/29/2020 9:23 PM
When talking about the 1960 optional 261 you are beginning to travel down the river stix (spelling, don't believe that stuff). the optional 261 in 1960 had for both the automatic and standard shift a #57 metering jet. In my opinion the 57 is a good all round metering jet. Unless you have a 261 from a bus that was governor equipped from factory then you need a #42 jet. This is a Rochester BC carb. If there is any evidence of a governor attached throw it away and go with your exiting BC. Most governor's at the time kept the speed at 45 mph. I'm a Rochester/Carter Nazi so you may need advice from tclederman or hotrodlincoln. There is a gold mine of folks on this web-site that have pretty much seen it all. A plane old Model "B" with a choke pull off is my preference on all the oldies. Stuck in my ways Doc.
ndkid275 #1367131 06/30/2020 1:48 PM
I'm running the correct carb for my 261, engine was a 62 casting, it came with its original carb and it is a Rochester B with a 64 metering jet. Engine was out of 1-1/2 ton truck. Now I do remember my 235 with a rochester B had a smaller venturi with a smaller jet believe a 58
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
ndkid275 #1367226 06/30/2020 10:44 PM
Thanks! I know my 216 carb won’t fit, so looks like I will be looking for one to rebuild!
Chris
ndkid275 #1367904 07/06/2020 12:12 AM
I replaced the Rochester B on my 1960 261 with a 32/36 progressive 2 barrel carb from Tom Langdon & love it.
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
ndkid275 #1367945 07/06/2020 12:40 PM
Carburetion specialist
Tim - someone far wiser than I once said something to the effect: "if you haven't tasted steak, lunchmeat is great!" nanner
Jon.
The Carburetor Shop
ndkid275 #1527112 11/23/2023 10:07 PM
On my 1960 261 is a 2-barrel AA1 Zenith (from a GMC 302).
It has variable/adjustable jets added by me (added by my carburetor rebuilder, actually).
It has run flawlessly and economically for over 10+ years.
ndkid275 #1527152 11/24/2023 1:18 PM
AD Addict & Tinkerer
Tim, you do realize you posted on a three year old thread!
Phil
Project Journals
Stovebolt Gallery Forum
ndkid275 #1527154 11/24/2023 2:18 PM
Thanks, Phil
Yes, I knew - that carb info might help someone searching old threads for information.
If you are a moderator and you think my post should be deleted, please delete it
ndkid275 #1527160 11/24/2023 4:14 PM
Not my Forum to Moderate but..
I think adding new info to an old post is beneficial for those doing "research".
With only 31,856 posts, I think you you need to "up your game" and continue to help the rest of us with your experience and knowledge. ( humorous sarcasm )
I've only "been around" since 2014 and recall the many times you responded to posts with helpful information and guidance.
Thanks Tim, we appreciate you!
Ron - - Dusty53
1954 Chevy 3604
ndkid275 #1527173 11/24/2023 6:20 PM
Authorized Pest
Authorized Pest
Agree, on all counts. Tim, you are a great source of information and always very willing to share. (And you do good links. wink ) Thanks for all that and more.
~ Peggy M
1949 Chevrolet 3804
ndkid275 #1527195 11/24/2023 10:49 PM
I also agree, Tim has been a mainstay on this ship we call “Stovebolt” for many years now. The top #1 poster on this forum. Always offering good advice and good information. Thanks Tim for all you’ve done to support our hobby. Since number two is OK with this thread, I see no reason to delete anything.
Phil
Project Journals
ndkid275 #1527339 11/26/2023 2:05 AM
Thanks for the positive comments.
I posted this to help future readers/members.
I have always used Chevrolet Truck Data Books (TDBs) as sources of information/identification about Chevrolet Trucks, even though the TDB has not in the past been enough (here) to allow some TDB vehicles to be called a truck.
