2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#1526963 11/22/2023 6:18 PM
https://www.chevsofthe40s.com/detai...its_Car_And_12t_34t_and_1ton_Trucks.html
Anyone use this bushing mentioned above?
Thoughts, concerns, experience with installing?
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
That one says 37 to 39 if your tube is a 1950 it will be this one .Also the newer tubes 51to 54 are a bit bigger diameter so also different part .one way to tell your tube is a. 1950 is it will have dowel a dowel pin to hold the original bushing in the tube ,two pins one for each of the origional bushing as the origional is two instead of the newer oakie style .with the oakie you only need to remove the dowel closest to the tranny end as the other old bushing stays in .I never done this yet but read a lot of posts .Also measure the tube and new bushing before to make sure it will fit .There are a few videos on this also .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1526982 11/22/2023 9:07 PM
Link is generic photo of bushing, I will order correct one based on year of my truck. I'm looking for person or persons who have actually replaced their bushing and can provide feedback on the issue with installation if any, such as ease of installation, modification if needed and what and how they encountered.
Jim
You tube video by the jayhawker is a good one to watch ,I will be following this post as I have my bushing and will be installing soon
"The Journey"
Follow in the DITY
KEVINSKI #1526997 11/22/2023 11:12 PM
If possible document your experiance with pictures, as they say pictures are worth a thousand words. Keep us updated.
Jim
Yes I will I was going to do this last fall and took the old bushing out with the puller ,it was in there good and I had difficulties but it is out .I decided to take the rear cover off the diff and found some damaged gears so I was thinking gear swap but that is for another day .I found a good rear axle from a 49 and had to order the bushing that is for the older tubes .
"The Journey"
Follow in the DITY
FYI , everyone. We have decided to start a new thread for Kevinski, within "Driveline" so he can document his work. Thank you!
Ron - - Dusty53
1954 Chevy 3604
