0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#1525115 11/08/2023 8:22 PM
I have a original 4 spd. and rear diff. In my 42 1/2 ton
What oil and how much in each? Synthetic?
1942 Chevy 1/2 ton
2014 RAM Truck
Gary42 #1525122 11/08/2023 9:13 PM
7
7 Offline
Valvoline makes a manual trans lube in qt. squeeze bottles, Synchromesh MTF, I use it in my SM420 and have zero trouble with it. The rear differential needs a different lube, something for hypoid gears, 80W-140 or 75w-90. I think the tranny is around 9 pints? rear end on yours might be about the same amount.
Gary42 #1525123 11/08/2023 9:21 PM
H Online: Content
The crash box trans in your truck can use just about any 90 weight gear lube, since there are no synchronizers to get in trouble with the super slippery synthetic lubes. I'd suggest using a general purpose 90 weight hypoid lube in both the trans and differential. Later model transmissions like the SM-420 need a straight mineral oil without hypoid additives to keep from grinding gears on a downshift. The N-series Ford tractor specification mineral oil transmission lube sold by Tractor Supply is a good one to use in the 420, and hypoid gear lube in the rear end.
Gary42 #1525227 11/09/2023 5:49 PM
OK 90w, and 4.5 qts.for each??
Thank you for your responses.
1942 Chevy 1/2 ton
2014 RAM Truck
Gary42 #1525332 11/10/2023 11:57 AM
7
7 Offline
Gary42, I didn't put enough thought into my prior post, your transmission is a different model than mine, the SM420 has a sight plug on the side of the case, fill to 1/2" below with a cold tranny, fill to the bottom of the hole with a hot tranny. I suspect that your trans is similar but I have no experience with it.
Gary42 #1525348 11/10/2023 2:10 PM
Gary, Oh no, not "QTS"! nono That would way overfill both the transmission and axle. eeeek
The oil capacity amounts and type specifications are listed in detail in the original 1942 Chevy Truck Owners manual that you can read through at your leisure. The lubrication type and interval info is listed starting on Page 31 and the "capacities" begin on Page 51.
Let us know how your work progresses.
~ Dan
1951 Chevy 3 window 3100
Gary42 #1525495 11/11/2023 11:42 AM
7
7 Offline
Looks like 5.5 pints for the 4 speed and 4.5 pints for the rear axle.
Gary42 #1525544 11/11/2023 6:46 PM
I found the same capacities. Thanks again.
1942 Chevy 1/2 ton
2014 RAM Truck
Gary42 #1526828 11/21/2023 5:18 PM
Yes, Jerry, I use the old Ford tractor lube from Tractor Supply in my transmissions. 2 1/2 gallon container and inexpensive.
I invest my money in precious metals, mostly rust!
Question muncie 318 3spd transmission what gear oil should I be using?
There is some much info on GL 4 GL5 and others it makes it difficult to use the correct one, don't want to damage parts.
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
Gary42 #1527305 11/25/2023 11:45 PM
AD Addict & Tinkerer
Here is a link for Tractor Supply: Transmission, 90w mineral oil https://www.tractorsupply.com/tsc/product/traveller-ford-tractor-hydraulic-oil-2-gal-t806600
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 #1527602 11/27/2023 8:43 PM
So the straight mineral oil from tractor supply is what is recommended.
Jim
