2 members (J Lucas, Erniegp),
78
Mod | | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | I have a original 4 spd. and rear diff. In my 42 1/2 ton What oil and how much in each? Synthetic?
1942 Chevy 1/2 ton 2014 RAM Truck
| | | | | Joined: Feb 2016 Posts: 1,985 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,985 | Valvoline makes a manual trans lube in qt. squeeze bottles, Synchromesh MTF, I use it in my SM420 and have zero trouble with it. The rear differential needs a different lube, something for hypoid gears, 80W-140 or 75w-90. I think the tranny is around 9 pints? rear end on yours might be about the same amount.
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The crash box trans in your truck can use just about any 90 weight gear lube, since there are no synchronizers to get in trouble with the super slippery synthetic lubes. I'd suggest using a general purpose 90 weight hypoid lube in both the trans and differential. Later model transmissions like the SM-420 need a straight mineral oil without hypoid additives to keep from grinding gears on a downshift. The N-series Ford tractor specification mineral oil transmission lube sold by Tractor Supply is a good one to use in the 420, and hypoid gear lube in the rear end. Jerry
| | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | OK 90w, and 4.5 qts.for each?? Thank you for your responses.
| | | | | Joined: Feb 2016 Posts: 1,985 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,985 | Gary42, I didn't put enough thought into my prior post, your transmission is a different model than mine, the SM420 has a sight plug on the side of the case, fill to 1/2" below with a cold tranny, fill to the bottom of the hole with a hot tranny. I suspect that your trans is similar but I have no experience with it.
| | | | | Joined: Sep 2009 Posts: 5,823 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,823 | OK 90w, and 4.5 qts.for each?? Thank you for your responses. Gary, Oh no, not "QTS"!  That would way overfill both the transmission and axle.  The oil capacity amounts and type specifications are listed in detail in the original 1942 Chevy Truck Owners manual that you can read through at your leisure. The lubrication type and interval info is listed starting on Page 31 and the "capacities" begin on Page 51. Let us know how your work progresses.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2016 Posts: 1,985 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,985 | Looks like 5.5 pints for the 4 speed and 4.5 pints for the rear axle.
| | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | I found the same capacities. Thanks again.
| | | | | Joined: Sep 2019 Posts: 158 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 158 | Yes, Jerry, I use the old Ford tractor lube from Tractor Supply in my transmissions. 2 1/2 gallon container and inexpensive.
I invest my money in precious metals, mostly rust!
| | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | Jerry Question muncie 318 3spd transmission what gear oil should I be using? There is some much info on GL 4 GL5 and others it makes it difficult to use the correct one, don't want to damage parts. Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 |
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | So the straight mineral oil from tractor supply is what is recommended. Jim
