| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | Our 1948 6400 2ton firetruck differential is a RG429 single speed. Can anybody tell me what it is and what we can replace it with for higher ratio. Thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lutrexen, The stock rear end ratio is 6.17:1 which is pretty low, are you trying to get more top speed, if so I would suggest an overdrive transmission or an accessory overdrive, rather than a differential gear change. That particular rear axle housing probably has a limited number of ratio options available. You could possibly swap in a newer diff. from a diesel powered truck , which may have ratios in the 4-5:1 range, hope that helps. | | |
