1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
#152680 05/15/2007 5:14 PM
Apprentice
Apprentice
Our 1948 6400 2ton firetruck differential is a RG429 single speed. Can anybody tell me what it is and what we can replace it with for higher ratio. Thanks
#152681 05/15/2007 8:39 PM
What ratio do you want?
1952 Chevrolet 3800 pickup
---All pictures---
#152682 05/15/2007 8:48 PM
3B Offline
Hy lutrexen, The stock rear end ratio is 6.17:1 which is pretty low, are you trying to get more top speed, if so I would suggest an overdrive transmission or an accessory overdrive, rather than a differential gear change. That particular rear axle housing probably has a limited number of ratio options available. You could possibly swap in a newer diff. from a diesel powered truck , which may have ratios in the 4-5:1 range, hope that helps.
