2 members (Peggy M, Gray_Ghost), 184 guests, and 1 robot.
Topics128,089
Posts1,056,116
Members48,434
OK. What should I do?
I go to paint supply house months ago and order straight tint for 66 c10 light blue. I finish it with this epoxy paint, return to paint house with the can of tint I need to replace. I thought I bought tint and then painted more parts. Had a horrible time getting things to cure and act right. Figured it was something I did. I go back today to buy more tint and find out the can I brought with me was for single stage paint not tint?
My epoxy paint specifically says tint. NO WONDER I AM HAVING SUCH PROBLEMS! Now I potentially have over 1200 in product, and possibly a paint job ruined. Countless hours wasted.
Do I just eat this or do I have reasonable gripe paint house needs to make right? I don't even know what right is?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
So you went to buy tint, mixed what you bought into the expoxy, and sprayed it?
So you mixed single stage paint into your epoxy instead of tint?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Yes. I specifically asked for tint only. Got single stage and I mixed into epoxy not knowing it was single stage.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
O Online: Content
I think you have a legitimate complaint. What does it say on the receipt? Does it say "Tint"? Or does it say "Single Stage Enamel" or whatever?
If it says "tint" on the receipt or the can, then you definitely have recourse. Whether the store will help you without suing them in small claims court is another story, though.
1950 Chevrolet 3100 (Ol' Roy)
It's all the industry jargon numbers and letters. That's what I tried to tell him. None of that information I understand not being a painter. I am relying on the expertise of him to get me what I need. I have explained in detail what product I was using and what I needed.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Hey there, Mark. This is a headache for sure and explains your problem.
Looking at the issue from a distance I would send a complaint or hand it to them in writing. Factually list the issue, your dependence on their expertise, and the hours and money you have in this effort and summarize with what you reasonably want from them.
Depending on their goodwill to make it right or not…send it to their next level supervisors too. Ask them for that contact information.
Try to get something back from them. But here may be the hard part: this project should be fun yet hard and rewarding work too. Do what you can with corporate, and after you hear back, whether in your favor or not; move on.
Strip it if necessary and repaint. In time and as you move forward with the prject the sting will lessen, and you will have a war story to tell and teach. That may be the reality but I hope they refund you something. It hurts in the pocket book, I know. Once people get their money it’s like permanent stickum and anything less than that becomes your problem and not theirs. - try to move on and take steps forward. In the end it’s their reputation that suffers in spite of the profit. tom
1946 GMC Project
"Back-in-the-day Restore"
O Online: Content
Is the pART THAT ALREADY DRIED looking good? Does it appear that it will be ok in the long run?
What did the epoxy maker say about the problem? Maybe he can give you some advice if he knows what's been mixed with it.
Will be calling epoxy maker Monday morning.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
O Online: Content
Keeping my fingers crossed. It seems like the stuff you painted first has hardened up nicely, though, right?
Yes. It eventually seemed to harden up. There is definitely some color variations which I attribute to the two sets of chemicals not wanting to mix right. I don't consider it an issue because once assembled the truck will be shot as one to eliminate this and correct any assembly damage.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
My concern with this is if the final topcoat will bond properly to the mixed version.
I don't think that will be an issue as long as everything cured.
Will probably need a light scuff before the final coat.
7
7 Offline
I think I would shoot a primer-sealer prior to a topcoat, find out from the supplier what type of sealer would be compatible with the topcoat.
I was pretty sure this was his final coat.
Mark, He said he was going to shoot another coat after assembling.
Ah, missed that. So, maybe find a hidden place to do a test. See if the substrate will hold up.
I don't want to seal before another coat. Then I am starting over with color and I was hoping the final few coats will give uniformity. I know I will need to scuff for final round but color will remain.
Hoping for positive info from manufacturer tomorrow. Got .y tent done and test heated it today. I can easily bring cab up to 100 degrees which is going to help.set this stuff up so much faster.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Spoke with epoxy manufacturer. He said adding paint vs tint is OK, but did cause my curing problems and I needed to have added more to it to get the same color which was another issue when I did my bed pieces.
This made me feel a ton better.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
That is good news.
