2 members (homer52, Tronman), 113 guests, and 5 robots.
Topics128,077
Posts1,056,033
Members48,433
#1525856 11/13/2023 10:15 PM
Hey guys/gals, I was just wondering if anyone else has run into this problem. I picked up this '70 C10 which used to be a 6 cylinder but now has a 350 in it. I would like to replace the "flex" lower radiator hose with a formed hose but I found that the water pump has a 2" inlet and the radiator has a 1 1/2" outlet (I assume because it originally was a 6 cylinder.? Does anyone know of a hose that will work on this combo? Surely I'm not the first to be in this situation. Thanks for any help. Steve
Foss #1525866 11/13/2023 10:34 PM
A friend who owned a radiator shop out in California close to mine back in the mid-1970s showed me a trick. Cut a short spool off the smaller diameter hose and slip it over the radiator nipple. Then slide the bigger hose over it DRY- - - -no sealer or lubricant, and tighten a worm drive clamp over the whole works. Crank the clamp down TIGHT! It will hold all the pressure the cooling system cam generate, without slipping. Works like a charm!
R Online: Content
The upper hose on my '47 had been done like Jerry suggested. Worked great. I wasn't even aware of it till I one time decided to replace the hose.
Don't recall for sure what I did, as it's been several years ago. I think I just replaced it with a flex hose.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Foss #1525944 11/14/2023 11:11 AM
7
7 Offline
Using the rubber bushing works well if the diameters match, I recently used that method on installing a tee in the heater hose on my '57, no leaks.
Thanks guys. I have seen that done on old bikes on the gas line where the petcock outlet and carb spigot didn't match but never thought about it for this. I'll give it a try.
