1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | Hi all, Just to drop a note to those that helped with the double clutch dance.I am getting better at it and it's amazing how you just can't be in a hurry and it goes real well.However after driving it i found at the rear wheel there is a leak.It is pretty thick oil and the brake fluid is not dropping.SOOOO IT LOOKS LIKE THE NEXT STEP IS TO TEAR IT APART .But i was wondering is there any tips or little tricks before i start?I'm guessing there is a seal that has to be pressed off and a new 1 pressed on.Well thanks again for the clutching advice,it run's so smooth.It sure has been worth every minute i have spent on it. Chad | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | There is a proceedure in the repair manual. If you don't have one you can check out the online manuals. If that doesn't work I can send you the pages. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | One thing I don't know is where to buy the seals. I had to make the last set out of copper. Anyone have an ideas on where to purchase them? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | NAPA is a good start, you may have to have the old ones in hand though. Grigg | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | Thank's i will try to find an on line repair manual.If i don't have any luck and you have time to send the repair pages that would be greatly appreciated( [email protected]).I hope everyone enjoys the summer and safe driving,I'm off to the garage -shop rag's and maybe a COLD BREW AFTER.Chad | | |
