7 members (Mike in Sycamore, Leo, Gdads51, 1955 1 Series, Bill Trotter, cmayna, ShopRag), 109 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
#152574 05/11/2007 10:50 PM
Junior Member
Junior Member
Hi all, Just to drop a note to those that helped with the double clutch dance.I am getting better at it and it's amazing how you just can't be in a hurry and it goes real well.However after driving it i found at the rear wheel there is a leak.It is pretty thick oil and the brake fluid is not dropping.SOOOO IT LOOKS LIKE THE NEXT STEP IS TO TEAR IT APART .But i was wondering is there any tips or little tricks before i start?I'm guessing there is a seal that has to be pressed off and a new 1 pressed on.Well thanks again for the clutching advice,it run's so smooth.It sure has been worth every minute i have spent on it. Chad
#152575 05/12/2007 12:40 AM
I
I Offline
There is a proceedure in the repair manual. If you don't have one you can check out the online manuals. If that doesn't work I can send you the pages.
#152576 05/12/2007 12:41 AM
I
I Offline
One thing I don't know is where to buy the seals. I had to make the last set out of copper. Anyone have an ideas on where to purchase them?
#152577 05/12/2007 1:28 AM
NAPA is a good start, you may have to have the old ones in hand though.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#152578 05/12/2007 1:45 AM
Junior Member
Junior Member
Thank's i will try to find an on line repair manual.If i don't have any luck and you have time to send the repair pages that would be greatly appreciated([email protected]).I hope everyone enjoys the summer and safe driving,I'm off to the garage -shop rag's and maybe a COLD BREW AFTER.Chad
