8 members (HandyAndy, 52Carl, 55shaker, Cosmo, RoadsScholar, Jay R, Ponchogl, 1 invisible), 76 guests, and 0 robots.
Topics128,049
Posts1,055,629
#1525662 11/12/2023 3:58 PM
I am looking for motor mounts for my 230.(1963} I bought a pair from Advanced Auto everything lines up, however the bolt that joins the mount to the frame is much smaller. I went back to the store and they offered no option other than returning them. do you know of a direct replacement. I can use a smaller bolt but being there are only two bolts I kind of think bigger is better
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
BoToepfer #1525663 11/12/2023 4:07 PM
Can you drill out the bolt holes in the motor mount to allow use of the larger bolts? Pictures are always helpful, so I'm guessing here.
Ron - - Dusty53
1954 Chevy 3604
Dusty53 #1525673 11/12/2023 5:15 PM
My apologies. The new part I bought is Anchor #2282
BoToepfer #1525674 11/12/2023 5:30 PM
From the pictures, it doesn't look a lot smaller?
What size bolts are each of them? The new one has a larger isolator, which would be nice.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
BoToepfer #1525682 11/12/2023 6:20 PM
Here's one from Summit with a different part number...maybe call them to confirm the bolt size.
https://www.summitracing.com/parts/...QxiTgtv60OdI9YRAR0aAqDGEALw_wcB#overview
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
BoToepfer #1525690 11/12/2023 6:39 PM
Just measure the big bolts are 3/8 the smaller 7?16 I will buy smaller bolts and call it victory !
BoToepfer #1525705 11/12/2023 7:41 PM
Riding in the Passing Lane
That should be 7/16 bolt size. Are you sure 7/16 won't screw in there? It may have some loose rubber or dirt in the hole. Do you have a 7/16 tap or thread chaser?
You have to be careful using a 3/8 bolt in a 7/16 hole. It feels like it goes in nicely but actually does not fit good & will pull out under stress.
A time saving tip on those is to drill the hole in the frame bracket oversize so it makes it easier to get the bolt started. The thick washer it uses will take up the extra clearance.
George
1972 Chevy c10 Cheyenne Super
BoToepfer #1525729 11/12/2023 10:12 PM
7/16 is larger than 3/8
Did you type those backwards? Or is the thread larger and the hole jusst looks smaller from the rubber impinging on it?
Fibonachu #1526560 11/19/2023 2:00 PM
I must have
