| | | Forums66 Topics128,133 Posts1,056,395 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 8 New Guy | | New Guy Joined: Jan 2006 Posts: 8 | We thought we had a head gasket problem but a compression test showed 70+psi in all 12 cyl. Engine had been started a couple of times and was running rough. We started to take it out for a drive it started out rough then seemed to get more power but started belching gray/white smoke. There is a little water in the oil now. Does anyone think it can still be a head gasket problem if my compression is good?
Dave | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | Sounds like a head gasket to me. Could also be a cracked head/block. We will hope for a head gasket. Since you have the new head gaskets on the way go ahead and take the head off and see what you have going on. | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | 70 psi doesn't sound very good to me :confused:
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Did you check both the head and block for cracks and flatness before reassembly? Grigg | | |
