3 members (NJC, 1955 1 Series, baldeagle), 64 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#152521 05/08/2007 12:54 AM
Took Bertha out for a run yesterday....went quite a way and brought her home. Today I want to run her and blew alot of black soot out of the tail pipe...also noticed that when she lugged she blew some oil smoke...and everytime I shifted she puffed oil smoke...She has a 1966 261 straight 6 in there....one speed rear end
HELP....
Matt
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
#152522 05/08/2007 1:47 AM
Are you sure its a '66? I know some Canadian Pontiacs used a 261 into the 60's but otherwise that motor went out of production at the end of 1962.
Otherwise first thing I would do is pull the plugs and 'read' them. Are they oily or sooty?
#152523 05/08/2007 2:50 PM
no not sure....it was a 1966 straight 6 with the large valve cover on it....blue...and it is a Chevrolet motor...still puffs on shifts and smokes a bit when it lugs going up a hill....not a lot but enough for me to see.....
#152524 05/08/2007 5:12 PM
How many bolts hold the valve cover down?
Why have you titled this "283 EC", when it isn't a 283?
#152525 05/08/2007 6:02 PM
naddaclue,
Regardless of what engine your 1947.1 283EC GMC 3-Ton has in it, this problem sounds like worn valve guides. Any true black smoke would be excess fuel, but as you are aware, the blue smoke is burning oil.
Stuart
