| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | Took Bertha out for a run yesterday....went quite a way and brought her home. Today I want to run her and blew alot of black soot out of the tail pipe...also noticed that when she lugged she blew some oil smoke...and everytime I shifted she puffed oil smoke...She has a 1966 261 straight 6 in there....one speed rear end
HELP....
Matt | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Are you sure its a '66? I know some Canadian Pontiacs used a 261 into the 60's but otherwise that motor went out of production at the end of 1962.
Otherwise first thing I would do is pull the plugs and 'read' them. Are they oily or sooty?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | no not sure....it was a 1966 straight 6 with the large valve cover on it....blue...and it is a Chevrolet motor...still puffs on shifts and smokes a bit when it lugs going up a hill....not a lot but enough for me to see..... | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | How many bolts hold the valve cover down?
Why have you titled this "283 EC", when it isn't a 283? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | naddaclue,
Regardless of what engine your 1947.1 283EC GMC 3-Ton has in it, this problem sounds like worn valve guides. Any true black smoke would be excess fuel, but as you are aware, the blue smoke is burning oil.
Stuart | | |
