3 members (Nick in Manitou, Forty9, 1 invisible), 133 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#152514 05/07/2007 11:08 PM
Junior Member
Junior Member
hello i got a 47-53 truck its got no id plate. no emblems but has two speed rear end.dually rear. what the easiest way to id if 1 1 1/2 etc count the spring leafs?etc thanks for your time.
phil
#152515 05/07/2007 11:18 PM
'47, & '48 had frame mounted fuel tank, on right side of frame. '49, & '50 had inside cab fuel tank, with solid one piece door glass. '51 was only year with pull down door handles, & door vent glass. '52, &'53 look identical, except '52 models have "Chevrolet" script emblems, on hood, & '53's have "numeral" ie, "6400",on hood.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#152516 05/08/2007 1:53 AM
Chevy or GMC?
With a 2-speed its probably a 2-ton.
With a 1-1/2 parked next to a 2-ton its not hard to tell which has the stouter axles just looking at the rear hubs. I don't know if the spring count differs or not, but you can look that up in the restoration pack.
Look up Keith Hardy's page of online tech stuff to find a restoration pack online.
#152517 05/08/2007 6:14 AM
1 1/2 ton will be rated as 14000lb. gvw., 2 ton will be rated as 16000lb. gvw. This will be on the ID plate in the driver door jamb. Get the info., from this plate, & post it here.
Spanky Hardy
1950 GMC 250 1-Ton
#152518 05/09/2007 2:48 AM
Junior Member
Junior Member
spanky sorry no id plate its missing no title
.it has right side mountd fuel tank so it a 48 49
old sub its a chevy
#152519 05/09/2007 3:09 AM
If it has a right side, frame mounted fuel tank, & no tank in the cab, behind the seat. It's either a '47, or '48 model. '49, was the first year, for the inside the cab fuel tank.
Spanky Hardy
1950 GMC 250 1-Ton
#152520 05/09/2007 5:11 AM
Press in front hub caps, or bolt on caps? This would be either 1.5 or 2 ton respectively.
You can also measure the thickness and size of the frame material and check this in the service manual to see what size truck.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
