| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 10 Junior Member | | Junior Member Joined: Apr 2007 Posts: 10 | hello i got a 47-53 truck its got no id plate. no emblems but has two speed rear end.dually rear. what the easiest way to id if 1 1 1/2 etc count the spring leafs?etc thanks for your time. phil | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | '47, & '48 had frame mounted fuel tank, on right side of frame. '49, & '50 had inside cab fuel tank, with solid one piece door glass. '51 was only year with pull down door handles, & door vent glass. '52, &'53 look identical, except '52 models have "Chevrolet" script emblems, on hood, & '53's have "numeral" ie, "6400",on hood. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Chevy or GMC?
With a 2-speed its probably a 2-ton.
With a 1-1/2 parked next to a 2-ton its not hard to tell which has the stouter axles just looking at the rear hubs. I don't know if the spring count differs or not, but you can look that up in the restoration pack.
Look up Keith Hardy's page of online tech stuff to find a restoration pack online.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 1 1/2 ton will be rated as 14000lb. gvw., 2 ton will be rated as 16000lb. gvw. This will be on the ID plate in the driver door jamb. Get the info., from this plate, & post it here. | | | | | Joined: Apr 2007 Posts: 10 Junior Member | | Junior Member Joined: Apr 2007 Posts: 10 | spanky sorry no id plate its missing no title .it has right side mountd fuel tank so it a 48 49
old sub its a chevy | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If it has a right side, frame mounted fuel tank, & no tank in the cab, behind the seat. It's either a '47, or '48 model. '49, was the first year, for the inside the cab fuel tank. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Press in front hub caps, or bolt on caps? This would be either 1.5 or 2 ton respectively.
You can also measure the thickness and size of the frame material and check this in the service manual to see what size truck.
Grigg | | |
