3 members (3B, Lonnie, klhansen),
60
Mod | | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | I have a line on a 65 C20 for sale, was really wanting a C10 but this truck is a real descent truck, 100% original, complete & running/driving. Is there a ring & pinion or center section swap to have a more highway friendly ride or would it have to be a whole axle swap? Also what were the gear choices in the C20's? It also has the 16" split rims, are there a particular set of 8 lugs I should be looking for? I dont want to go real wide. Thanks
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Once you know what rear end it has you can order what you need to bring it down. Might need to buy a center section but I would think you could get down to a 3.73 easily.
Wheels are easy. 8.lug with a standard offset. Actually any of the big 3 wheels will fit I think.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | The 4.10 center section that was used behind automatic transmissions is a direct swap into the Chevy corporate housing. Those gears are not being produced new by anyone, and OEM is extremely scarce and pricey. The usual ratio for a stick shift C20 is a 4.56. There's a Dana type 60 8 lug rear that was used by GMC that's also pretty scarce, but there are all sorts of aftermarket ratios available for that one. I've got one of them under a 59 Suburban with a 3.73 gearset for a Ford, in a GMC housing. Jerry
| | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | Thanks for the replies. "Hotrod Lincoln" just spoke to a guy today who has one of the 4.10 center sections available, I'll have to see tomorrow what he'll want for it. On a side note I have a friend who has a Brownie OD auxiliary box available, that could be an interesting alternative. | | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | The guy I mentioned previous has the complete 4.10 rearend from a '72 for $500, is that good, bad or average priced? | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | If you don't want it at that price, I'll be glad to come and get it! Be sure to give him a big wet kiss when you pick it up! Can you post a pic of the Brownie? I might want to make an offer on that, if it's the right size for a medium duty truck. Jerry
| | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | I take it thats a real good price, especially for the whole axle  | | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | I ended up with both, gotta get em while the gettin's good. The aux box is a Spicer 3spd, OD/Direct/UD, about the size of an SM420. Not sure how to post photos.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | does your aux box have a park brake on the back of it? | | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | | | |
