1 members (delky), 127 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
1 Offline
I have a line on a 65 C20 for sale, was really wanting a C10 but this truck is a real descent truck, 100% original, complete & running/driving. Is there a ring & pinion or center section swap to have a more highway friendly ride or would it have to be a whole axle swap? Also what were the gear choices in the C20's? It also has the 16" split rims, are there a particular set of 8 lugs I should be looking for? I dont want to go real wide. Thanks
Once you know what rear end it has you can order what you need to bring it down. Might need to buy a center section but I would think you could get down to a 3.73 easily.
Wheels are easy. 8.lug with a standard offset. Actually any of the big 3 wheels will fit I think.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
The 4.10 center section that was used behind automatic transmissions is a direct swap into the Chevy corporate housing. Those gears are not being produced new by anyone, and OEM is extremely scarce and pricey. The usual ratio for a stick shift C20 is a 4.56. There's a Dana type 60 8 lug rear that was used by GMC that's also pretty scarce, but there are all sorts of aftermarket ratios available for that one. I've got one of them under a 59 Suburban with a 3.73 gearset for a Ford, in a GMC housing.
1 Offline
Thanks for the replies. "Hotrod Lincoln" just spoke to a guy today who has one of the 4.10 center sections available, I'll have to see tomorrow what he'll want for it. On a side note I have a friend who has a Brownie OD auxiliary box available, that could be an interesting alternative.
1 Offline
The guy I mentioned previous has the complete 4.10 rearend from a '72 for $500, is that good, bad or average priced?
If you don't want it at that price, I'll be glad to come and get it! Be sure to give him a big wet kiss when you pick it up! Can you post a pic of the Brownie? I might want to make an offer on that, if it's the right size for a medium duty truck.
1 Offline
I take it thats a real good price, especially for the whole axle smile
1 Offline
I ended up with both, gotta get em while the gettin's good. The aux box is a Spicer 3spd, OD/Direct/UD, about the size of an SM420. Not sure how to post photos.
Big Bolt Forum Moderator
does your aux box have a park brake on the back of it?
Mike
1 Offline
"69Cuda" It does not.
