5 members (JW51, 1955 1 Series, Gdads51, 55shaker, 1 invisible), 131 guests, and 3 robots.
Topics128,070
Posts1,055,900
Members48,429
#1524686 11/05/2023 5:49 PM
1 Offline
A while back (weeks not months) the subject of unobtainable Huck drums came up again. One suggestion was that perhaps they could be relined with new cast iron liners. Someone gave a link to an outfit that does specialty automotive drums, Corvette, Pontiac Gran Prix, Buick GS, etc. I contacted them and they replied that 12" drums was the biggest they could do. That would work for 1-ton front and 3/4-ton rear Huck brakes. Apparently, it dependes on how much material would be left after machining them out to fit the liners. Here's their reply:
Hey Thomas, Thanks for reaching out to us with your question. We mostly reline/refurbish auto's your request is near the limits of what we normally do but we have worked on them, we only carry some sizes of cast iron liners. We do carry 12" liners and most likely we can repair them with the hope that the side walls are not to thin and it would have to be measured to tell. I think some pictures would help to come up with some sort of quote for you, also we reline Brake shoes and offer Arc/Cam grind them to match the new drum size which gives you 100% contact between drum liner and Brake shoe. Hope this helps and call if you have any questions.
I'm wondering it it might be more worth their while if there were several jobs lined up so they could use the same setup. They didn't quote a price.
The company is:
J&G Drum Relining, LLC
Aluminum Brake Drum Relining
McHenry, IL.
815-276-2578
Don Booker
1951 3800 1-ton
In the DITY Gallery
Jim Carter sells new Huck Drums (although I see you're looking for a 1 ton truck. I haven't looked to see if they carry any for those)
You may also contact this company for help:
Brake Materials & Parts Inc
Specializing in antique, vintage, classic, obsolete, unique and hard-to-find brake parts, bonding, riveting, rebuilding, drum and rotor machining, custom made brake hoses
800 Sherman Boulevard
Fort Wayne, IN 46808
260-426-3331
http://www.brakematerialsandparts.webs.com/
1950 Chevrolet 3100 (Ol' Roy)
