6 members (Otto Skorzeny, KEVINSKI, HandyAndy, Hugh63c10, klhansen, 37 GC), 144 guests, and 1 robot.
Topics128,114
Posts1,056,607
Members48,450
#1524623 11/04/2023 11:07 PM
How do you get it smooth?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
When I put seam sealer on my truck, I made sure there were minimal boogers on it. It looks like you could have smoothed it out a bit more before it set up. Put on a pair of nitrile gloves and run your finger along it to smooth it out. I can't say that I've attempted to sand it.
Take a look at the Technical Data Sheet for the seam sealer you used and it should tell you if it's sandable. I used a 3M 2 part product and it was sandable and easy to sand.
Ron - - Dusty53
1954 Chevy 3604
7
7 Offline
The only seam sealer I used could not be sanded.
You might have used a two part flow grade on gutter and underside as well, tape both sides and pull tape before cures. Pat66
Well I was not going to grind it out. Got it close with a razor blade went after it with 100 grit, cleaned it and shot the cab with the last round of primer.
Next time I will know better.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
