2 members (J Lucas, Otto Skorzeny), 101 guests, and 6 robots.
Topics128,186
Posts1,057,209
Members48,465
My truck has a 1979 Pacer front suspension and I was driving it today in a crosswind and it was a little squirrely. Would an anti-sway bar help with that? Also, I have a 1979 Nova rear suspension, and would installing one on the rear help?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I doubt it would help. Sway bars work because one side of the vehicle wants to be lower to the ground than the other side, as when turning a corner.
7
7 Offline
There are actually anti- sway bars AND anti-roll bars, what most folks here are referring to as anti-sway are really anti -roll bars. They help reduce body roll when cornering. In a cross wind, an anti-sway might add some benefit IF one could fit it. I've not seen an anti-sway on the front end of a vehicle. Anti-sway may also be called a Panhard rod.
There was an original equipment "ride-stabilizer" bar/assembly on 1954 1/2-ton Chevrolet Suburbans
3106 and 3116 - with rear-doors or with lift-gate or end-gate (clam-shell).
This?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Ron,
Your Pacer front suspension came with a "stabilizer bar", unless it was removed during install onto your truck.
See the screenshot below and look at your "stabilizer bar" mount brackets and tie bolts (both sides of the suspension).
It's possible that after all the years you have had the unit installed that one or more of the mounts or tie bolts has failed and isn't keeping the bar firmly attached to the suspension and doing it's job. headscratch
Your suspension is due for a closer inspection/evaluation and possible maintenance.
Guitplayer,
That's the right "original style" unit for the truck, but won't work with Ron's later "Pacer" front suspension (it aint stock). wink
~ Dan
1951 Chevy 3 window 3100
Ron,
You need an AMC mechanic to check all of the steering and front suspension components. He should be about as busy as the Maytag repairman is these days.
You have had your truck for a while. Parts wear out.
