0 members (), 128 guests, and 0 robots.
Topics128,035
Posts1,055,560
#15240 12/04/2004 5:10 PM
Apprentice
Apprentice
Has anyone tried to fit the road demon 2bbl carbs (Part# 1181230M) to the offenhauser 235 two carb intake? The demon carbs have the same base plate dimensions as the holley 2bbl carbs(#7448 & #4412) Which are the carbs that I think some people have used with the 2x1 intake. If anyone has used the demon or holley set up let me know. I dont care to spend $600 on carbs that wont fit. Thanks
1953 3600 w/ full pressure 235
"Quando Omni Flunkus Moritati"
--If all else fails, play dead.
#15241 12/05/2004 5:04 AM
H Online: Content
Demon carbs are Holley clones, and I really don't see the reason th spend the extra bucks. The Holley 350 CFM 2-bbl. carb, list # 7448 is available for under $200.00 some places, and that's all you really need. One of those carbs is plenty to power a 235, so just install a blank gasket under the other one, and get a hot-looking setup that will actually run right.
