| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15240 12/04/2004 5:10 PM | Joined: Dec 2004 Posts: 33 Apprentice | | Apprentice Joined: Dec 2004 Posts: 33 | Has anyone tried to fit the road demon 2bbl carbs (Part# 1181230M) to the offenhauser 235 two carb intake? The demon carbs have the same base plate dimensions as the holley 2bbl carbs(#7448 & #4412) Which are the carbs that I think some people have used with the 2x1 intake. If anyone has used the demon or holley set up let me know. I dont care to spend $600 on carbs that wont fit. Thanks
1953 3600 w/ full pressure 235 "Quando Omni Flunkus Moritati" --If all else fails, play dead.
#15241 12/05/2004 5:04 AM | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Demon carbs are Holley clones, and I really don't see the reason th spend the extra bucks. The Holley 350 CFM 2-bbl. carb, list # 7448 is available for under $200.00 some places, and that's all you really need. One of those carbs is plenty to power a 235, so just install a blank gasket under the other one, and get a hot-looking setup that will actually run right. Jerry
