1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1523997 10/30/2023 1:05 AM
Do I have to remove anything to get to the 2nd freeze plug on driver’s side of engine on a 235 ??
This is no longer fun
1 Offline
To make things easy on yourself, pull the manifold assembly.
1951 3800 1-ton
In the DITY Gallery
Remember... there is one on the rear of the block hidden by the bellhousing... bummer.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Working on press fit freeze plugs with the engine in the vehicle is a PITA. I'd suggest using the rubber expansion plugs, after a good cleanup with a wire brush in a drill motor. Pull the manifold assembly and those oil lines to get better access to the side of the engine to remove the old plugs and clean the block.
Has anyone used an auto body slide hammer/dent puller?
To get freeze plugs out of a 235 with manifold still on engine?
They aren't that tough. You can knock them in with a chisel and pull them out with pliers.
1950 Chevrolet 3100 (Ol' Roy)
Cool thanks
latroca52 #1524228 10/31/2023 10:24 PM
If you don't have enough room with a chisel, try a longer punch. Drive it on one side only until it spins around, then use pliers. There is very little room.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
