6 members (rfs56trk, Gdads51, Hanks custodian, MikeStone1953, Shaffer's1950, Biermann), 74 guests, and 2 robots.
Topics128,084
Posts1,056,334
Members48,442
#1523650 10/27/2023 1:58 AM
I'd like to mount the spare tire under the bed on my stock 1951 GMC 100. Where can I find the right bracket to do this? All I run across is the J hook for a Chevy. What do I need?
If the '51 GMC is the same as the '51 Chevy, you'll need two u-shaped crosspieces that bolt under the top flange of the frame, and a bar that holds the spare tire, which pivots on a rod hanging from the front crosspiece driver's side and is secured to the rear crosspiece on the passenger side. Here's a picture of the spare tire bar (lower left of the collection.) And a picture of the Factory Assembly Manual page showing the assembly.
Welcome to Stovebolt smile
Here's a photo of what mine looks like. It seems that these parts are hard to find
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
Professional procrastinator
You should scan the parts for sale area here. These come up for sale every NOW and again.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
They're not that hard to find. The earlier (50 and before) spare carriers are the ones that are like hen's teeth.
Will the 51 and up fit on a '50?
Do the parts bolt on or are they welded in place?
1950 Chevrolet 3100 (Ol' Roy)
They bolt on. At worst, you'd need to drill some holes for the cross-pieces.
Chris H,
As "Twin Jimmys" mentioned in his reply above, check out the Swap Meet for something that will fill most of the parts you need just in case you might be interested. wink
~ Dan
1951 Chevy 3 window 3100
Thanks everybody
Here are some pictures of the one off my 53. Sorry about the quality it's cold, raining and I'm in my slippers.
Mine is from a 80,s chev under bed carrier they will fit with a few mods.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
