0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2022 Posts: 35 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 35 | Getting "correct" brake parts for this 12" 8lug is difficult... I'm def fed up with it enough to put a different rear end under it (Blahblahblah)
Is there a direct bolt in swamp? (That has brake parts on the market)
59 3E 3600
| | | | | Joined: Oct 2021 Posts: 6,962 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,962 | Is it drums you're looking for? Shoes can be relined. See if these guys can help you. Specializing in antique, vintage, classic, obsolete, unique and hard-to-find brake parts, bonding, riveting, rebuilding, drum and rotor machining, custom made brake hoses Brake Materials & Parts Inc 800 Sherman Boulevard, Fort Wayne, IN 46808 260-426-3331 http://www.brakematerialsandparts.webs.com/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Why not just adapt a newer complete brake assembly- - - -backing plates, shoes, drums and all, to the existing hubs and housing? You've got a choice of all kinds of 8 lug axles with the same wheel bolt pattern to choose from- - - -Dodge, Ford, GMC, International, and a few others. Many of them run the same Dana type 60 axle, which would be a pretty simple swap if you're determined to abandon one of the best full floater rear axles ever made. Jerry
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I found a dana 60 out of a 1963 gmc 2500. 8 lug looks like it will bolt in with out any mods. gear ratios avail 410 to 340.i lucked out and it turned out to be a limited slip.
| | | | | Joined: Sep 2011 Posts: 1,460 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,460 | I found a dana 60 out of a 1963 gmc 2500. 8 lug looks like it will bolt in with out any mods. gear ratios avail 410 to 340.i lucked out and it turned out to be a limited slip. Should have a pow-r-loc Good set up!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | You'll find that there's a slight mismatch on the width of the spring mounting pads on the axle assembly. I was in a hurry to install the one from a 1970 GMC I put into my 59 Burb, so I forced the springs apart a little and bolted everything up. That was 40 years ago, and it's still there! Jerry
