2 members (Otto Skorzeny, 1 invisible), 107 guests, and 5 robots.
Topics128,193
Posts1,057,253
Members48,466
Getting "correct" brake parts for this 12" 8lug is difficult... I'm def fed up with it enough to put a different rear end under it (Blahblahblah)
Is there a direct bolt in swamp? (That has brake parts on the market)
59 3E 3600
O Online: Content
Is it drums you're looking for? Shoes can be relined.
See if these guys can help you.
Specializing in antique, vintage, classic, obsolete, unique and hard-to-find brake parts, bonding, riveting, rebuilding, drum and rotor machining, custom made brake hoses
Brake Materials & Parts Inc
800 Sherman Boulevard,
Fort Wayne, IN 46808
260-426-3331
http://www.brakematerialsandparts.webs.com/
1950 Chevrolet 3100 (Ol' Roy)
Why not just adapt a newer complete brake assembly- - - -backing plates, shoes, drums and all, to the existing hubs and housing? You've got a choice of all kinds of 8 lug axles with the same wheel bolt pattern to choose from- - - -Dodge, Ford, GMC, International, and a few others. Many of them run the same Dana type 60 axle, which would be a pretty simple swap if you're determined to abandon one of the best full floater rear axles ever made.
I found a dana 60 out of a 1963 gmc 2500. 8 lug looks like it will bolt in with out any mods. gear ratios avail 410 to 340.i lucked out and it turned out to be a limited slip.
Should have a pow-r-loc Good set up!
BC
1960 C60 pasture art
You'll find that there's a slight mismatch on the width of the spring mounting pads on the axle assembly. I was in a hurry to install the one from a 1970 GMC I put into my 59 Burb, so I forced the springs apart a little and bolted everything up. That was 40 years ago, and it's still there!
