3 members (NAPCOStormTrpr, Lightholder's Dad, Gdads51), 82 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
#1523822 10/28/2023 4:32 PM
Have an original Rochester GM 1 barrel carb that I want to rebuild. I haven’t taken it off the engine yet and was wondering if there is a number or stamping somewhere on the carb that will assist in procuring the correct rebuild kit. Thanks in advance for the assistance.
Moderator, Electrical Bay
There may or may not be a triangular shaped brass tag attached to one of the 4 screws that holds the airhorn to the float bowl. If there is, it will have a number. If not, you should contact Jon (CarbKing) on Monday or Tuesday at The Carburetor Shop: https://www.thecarburetorshop.com/Orderinfo.htm
He will be able to tell you what you need. Good luck!
~ Jon
Insomniac
Insomniac
Some of the carbs have a number stamped on the flange. You have to remove the carb and turn it over to see if it's there.
BTW, you should always tell us what you are working on. Many (most?) of us add the info to our signature line so it's not forgotten.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Riding in the Passing Lane
What model Rochester carb. are you working on? What year truck is it?
George
1972 Chevy c10 Cheyenne Super
Mt310cw #1523861 10/28/2023 10:53 PM
Carb appears to be the original carb on my 1955.1 3100 235 engine. I presently do not know what model it is.
Mt310cw #1523865 10/28/2023 11:42 PM
That's what I was thinking based on your posts. There is a high likelihood your carburetor has been rebuilt by somebody (or maybe more than one somebody) along the way. If it has a manual choke it is likely a B model. If auto choke, somebody swapped a BC. Jon H can help you figure it out and will be able to get you the right kit. Soon there will be a TechTip dedicated to the Rochester and it may also be of help.
~ Jon
Mt310cw #1523867 10/28/2023 11:57 PM
Like Gord&Fran said... take it off, dump out the gas, clean the mounting flange real good and look for a number. That would be the model #. It was stamped then the surface was planed flat so it may not be visible without a good cleaning.
Also... not all flanges were stamped.
Get a pic of the carb and the inside of both halves. Get the # off of the little brass plug inside. Should be 58 for a 235.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
