| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Hey Guys, I'm re-wiring my '49 truck, (12 v), & using as many LED's as possible. Head & tail, interior...
Does anyone know of a source for LED light sockets for the dash lights? Keeping the stock gauges.
If not I'll go with the original style.
Thanks in advance. Rick | | | | | Joined: Sep 2009 Posts: 5,863 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,863 | Rick, Not sure what type "led" lamps you are talking about using in your dash. If you are using something like this led equivalent to the original style GE 55 incandescent lamps, you can just use your standard sockets. One thing to note on this particular lamp, the info does not indicate if this is a "dimmable" led lamp. If it's not, your dash light dimmer will not work with this lamp and you may need to do some further searching to find a dimmer compatible bulb. If you are wanting to upgrade your dash to newer no metal base bayonet style lamps (like currently used GE 194 style bulbs), you may want to consider these rubber push in style sockets. They should fit your dash panel holes I believe. On these sockets though, you will need to connect the second (black) wire to ground as the socket itself will not self ground when installed. Good luck with your "led" relighting project!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Gdads51 Thanks for the reply - Excellent information, just what I was looking for, Thanks !
I'm fine running the ground wire, My plan is to update the wiring, & new sockets / bulbs fill the bill.
Thanks Dan. I'm sure I'll have more questions along the way. | | | | | Joined: Sep 2009 Posts: 5,863 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,863 | Glad it's helpful.  A little further web looking this morning shows these dimmable GE55 LED replacement lamps that may interest you if you decide to use your original sockets. These are a bit pricier than the other bulbs I mentioned and actually are from an "aircraft" lighting source company. The given "specs" definitely seem to fill the need for upgrading to brighter dash lights for anyone looking to do that. If you decide to go that route, would be interested in any feedback you can provide on the lamps performance (or lack of). I would like to improve my dash lighting too and a simple plug and play would be nice.
In my 1st reply, the original base style LED lamp that fits your existing sockets are 6-28 volt rated so would work under 12 volt input.
The later suggested lamps are 6 volt specific, but there are 12 volt applications available.
Too late tonight to research. I will see what I can find in the morning and post what I find. 😉
| | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | That’s a nice find. I’d kinda like to try a couple and see how they work.
The description for both the 6v and 12v versions offer a disclaimer. Sounds like the dimmable range with a rheostat dimmer might be pretty narrow. Not sure that I really care, as long as the light isn’t blindingly bright.
1951 3100
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | That’s a nice find. I’d kinda like to try a couple and see how they work.
The description for both the 6v and 12v versions offer a disclaimer. Sounds like the dimmable range with a rheostat dimmer might be pretty narrow. Not sure that I really care, as long as the light isn’t blindingly bright. Let us know. That is generally the biggest problem with this kind of inexpensive led replacements. They just use a current limiting resistor, so the input voltage change between dazzling bright and off tends to be very, very small. Edit: this is a generalization of cheap led replacement bulbs as a whole, not this specific model. It would be somewhat interesting to know if this model has that issue or not. Having an extremely wide voltage range would be a mark in its favor of potentially working better.
