0 members (), 73 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
So I got my flywheel in that I needed for my 261 swap. When measuring across the clutch surface, I am measuring 10 7/8". Interestingly, I've found that the clutch from 42-46 had the same casting number for the regular flywheel and the heavy duty flywheel.
1. Will this require the 10 3/4" clutch discs? I'm about 95% sure it will but I want to be sure since theyre expensive. Jim Carter has new 10 3/4" ones but I haven't found them anywhere else. Everywhere else has 9 1/8, 10, and 11.
2. How hard is it to find 9 bolt pressure plates? I'm understood that they can't be had new.
~ Daniel Davidson
1939/1940 Chevrolet/GMC
Follow his Project Journal
About 50 feet from my back door. Clutch disc and flywheel to match.
Jerry,
Does it want to go on a field trip? Not having any luck finding a new one. Looks like original part number for the pressure plate was 838954 and superseded to 3836007. I figure I'd buy a new friction disc once I verify what size it's supposed to be
~ Daniel Davidson
Mine came from a spray-oiler 235 from the early 1950's. The flywheel has the 139 tooth ring gear for a 6 volt starter, I'm pretty sure. The pressure plate and disc can both be rebuilt, I'm sure. Drop me a PM so the PC Patrol doesn't get their fragile feelings hurt and let's make a deal!
Is there any reason not to drill and tap the flywheel for the more common (and less expensive) 6 bolt pressure plate? The flywheel doesn't know or care how many bolts are holding the pressure plate onto it.
