1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#1523389 10/25/2023 3:05 AM
The rear wheel cylinders are positioned at 9 & 3. How does one get all the air out? They have shields over them so you can’t access or take the top off.
Brake bleeding is covered in this manual. 1954 Chevy Truck Shop Manual. Should be the same as your '53
Thanks. Can I assume that all air will be removed from cylinder while bleeding even though it’s vertical?
That would be my guess. Make sure the brakes are adjusted up so there's a minimum of volume above the bleeder screw.
Thanks. I did take it apart but your smart enough comment has me wondering.
Moderated
Moderated
I am having the same problem on my 53 GMC. The brakes are more like the ones described in the older manual https://chevy.oldcarmanualproject.com/shop/1948_51truck/index.htm
Reading carefully, the manual instructs you to loosen the top brake adjuster on both rear wheels. This allows the piston to retract downward to help remove the air pocket / space above the bleeder screw opening inside the wheel cylinder. Bleed the brakes as normal, then adjust the upper adjuster back to its operating position. This makes sense, however I just performed this procedure and no luck. Still needs a pump of the pedal before getting any braking. On my truck, I am confident the issue is in the rear because I have plugged off the rear and the pedal is rock hard (no pumping).
This has been very frustrating.
7
7 Online: Content
For my 2 ton Task Force, the shop manual says to back the adjusters off when bleeding, I didn't do it that way. I adjusted all four wheels until I had HEAVY drag, rock the wheel back and forth and step on the brake to center the shoes, readjust if needed to get a heavy drag. Then I did a two man manual bleed the old fashion way. Once I had a solid peddle I re-adjusted the brakes at each wheel for a light drag. Mine is all stock, I rebuilt all 7 cylinders and the Hydrovac, new copper/nickel lines and new hoses, I have zero problems and very responsive brakes.
Have you tried using a Vacuum Brake Bleeder like this one?
https://www.harborfreight.com/pneumatic-air-operated-brake-bleeder-with-auto-refill-kit-57057.html
They work great, should suck the air right out!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
