0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I drove the 54 yesterday on errands and the brakes did not seem to be working correctly. I had to pump them to get a good feel that it was stopping correctly. I tend not to drive too close and also in the habit of pumping them to slow down. I had serious issues during the first part of this year so I had the brake system completely flushed twice at the same time. It seemed to clear the issue. I did drive about 300 miles in September with no issues but it was mostly traffic-free interstate travel BTW it has power brakes and an auxiliary fill point on the firewall. So I checked it and the fluid level was way down, still visible but it took about 2 fingers worth. I have not driven it sense.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | You've got a leak somewhere. Cracked line, leaky wheel cylinder etc.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | There are two reasons for the fluid level to go down, a leak, or the shoes/pads are wearing down and the fluid has to fill the cylinder/piston area.
| | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | Also... those brakes do not self-adjust. If no leaks and the shoes are OK, try adjusting until you barely hear a slight drag.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |  . ALL. The not adjusting is a thought I had also. The front suspension is from a 1979 AMC Pacer and the rear is a 1979 Nova. Thanks again. Btw I had never noticed a leak and it is parked in a garage.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | If it went down 2 fingers in 300 miles, you have a non-trivial leak. | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | If you are losing fluid and see no leaks, there is a possibility that it is being sucked into the engine if you have power brakes. My guess is that the rear shoes are soaking it up.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | No, the 300 hundred was a reference to a significant trip that did take not the totality of my driving since I last checked the brake fluid. From now on I will check it more often.
| | | | | Joined: Feb 2020 Posts: 47 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 47 | Pacer front end. Disk brakes up front? if so, as front pads wear down, fluid level will go down.
just retired and finally making headway on my project truck. 1940 GMC AC152.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | On my truck, two fingers is the entire life of the pads. Ron: We went through this whole bit last time. If you want reassured that there is nothing wrong with your brakes, you are in the wrong place. We want your truck to be safe and for you not to die in a crash. If you have to pump the brakes up, they have air in them. If you have gotten them bled and flushed multiple times with no change in that behavior, you have a leak that is letting air in. If you are still losing fluid on the scale of it being measurable in 4 months (the last time you told us you had the system flushed and bled was 6/20), your leak is non-trivial. It could very well only leak under pressure and that is why you don't see it on the floor, but you are leaking. Please Ron, get this fixed correctly before someone gets hurt. Edit: Previous Discussion
| | | | | Joined: Dec 2020 Posts: 1,970 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,970 | A leak will probably run down the inside of the frame. Run your finger down on both sides. If you have to pump them ,then there is air. Look at this video. You are close. www.youtube.com/watch?v=fphcB-wB4-Q&t=109s
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |  I don't have to pump them I do it as a habit. Even the other day it was stopping but it went to a hard pedal then I pumped and they stopped ok.
| | | | | Joined: Dec 2020 Posts: 1,970 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,970 | Just becareful. Thats the sign the brakes may just fail on you. I just read this.... " I had to pump them to get a good feel that it was stopping correctly. Brake pressure and fluid level should not fluctuate. Remember you have the parking brake as a backup.
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Ron, you should never have to pump your brakes and if by chance its "a habit" , as a friend I suggest you kick the habit. You should never have to pump your brakes or add brake fluid under normal circumstances. Having to pump your brakes is usually an indicator of air in the system. Having to add fluid means there is a leak.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | As I am sitting here thinking about things, like a walk in the park and a kiss in the dark, no not that. On all my trips to KC thinking back, as a matter of habit, I would check all the fluids including the brake fluid. The pumping of the brakes is because I don't wait until the last second to apply them. I do it to slow down prior to stopping not like the idiots I have to deal with who wait until the last second before they slow down thinking that the light will turn to green to accommodate their privileged existence.  As some one suggested, not having self-adjusting brakes is the reason for the need for fluid periodically.
| | | | | Joined: Dec 2019 Posts: 446 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 446 | If you have a more modern front suspension and rear end, those brakes are Bendix brakes rather than Huck and should be self adjusting. You’ve got a leak somewhere if you are adding fluid or a bad master cylinder, and or air in the lines if it is necessary to pump.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: May 2015 Posts: 11,137 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,137 | If you have a more modern front suspension and rear end, those brakes are Bendix brakes rather than Huck and should be self adjusting. You’ve got a leak somewhere if you are adding fluid or a bad master cylinder, and or air in the lines if it is necessary to pump. Depends on how modern the front brakes are. Self adjusting brakes were added by GM in 1963. I had a 72 K10 pickup that had self adjusting brakes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,934 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,934 | His car has AMC Pacer front end and Chevy Nova rear end. His brakes should self adjust but you never know what people have done to a vehicle when they "customize" it.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Otto, I don't know or remember. It was done back in 2012. I sometimes have a hard time remembering what I did yesterday.
