0 members (), 136 guests, and 3 robots.
Topics128,193
Posts1,057,259
Members48,466
Getting "correct" brake parts for this 12" 8lug is difficult... I'm def fed up with it enough to put a different rear end under it (Blahblahblah)
Is there a direct bolt in swamp? (That has brake parts on the market)
59 3E 3600
Is it drums you're looking for? Shoes can be relined.
See if these guys can help you.
Specializing in antique, vintage, classic, obsolete, unique and hard-to-find brake parts, bonding, riveting, rebuilding, drum and rotor machining, custom made brake hoses
Brake Materials & Parts Inc
800 Sherman Boulevard,
Fort Wayne, IN 46808
260-426-3331
http://www.brakematerialsandparts.webs.com/
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Why not just adapt a newer complete brake assembly- - - -backing plates, shoes, drums and all, to the existing hubs and housing? You've got a choice of all kinds of 8 lug axles with the same wheel bolt pattern to choose from- - - -Dodge, Ford, GMC, International, and a few others. Many of them run the same Dana type 60 axle, which would be a pretty simple swap if you're determined to abandon one of the best full floater rear axles ever made.
I found a dana 60 out of a 1963 gmc 2500. 8 lug looks like it will bolt in with out any mods. gear ratios avail 410 to 340.i lucked out and it turned out to be a limited slip.
Should have a pow-r-loc Good set up!
BC
1960 C60 pasture art
H Online: Content
You'll find that there's a slight mismatch on the width of the spring mounting pads on the axle assembly. I was in a hurry to install the one from a 1970 GMC I put into my 59 Burb, so I forced the springs apart a little and bolted everything up. That was 40 years ago, and it's still there!
