8 members (J Lucas, greenie-reddy, homer52, kades51, 55shaker, Gray_Ghost, 2 invisible), 157 guests, and 4 robots.
Topics128,260
Posts1,058,321
Members48,485
#1522133 10/16/2023 6:46 PM
Is the seal that fits over the rear bearing called the rear wheel oil seal/rear axle seal? what is the seal that is in the differential that
seals the axle as it passes into the differential or is there a seal there? i dropped off wheel bearings and seals to the mechanic and he
says i need rear axle seals- does he need another seal? thanks
Family truck 1953 1/2 ton w/216
weewilly #1522134 10/16/2023 6:51 PM
If you're working on a stock truck (the '53 1/2 ton), there's no inner seal on the differential. Just the seals outboard of the axle bearings.
Print the attached pic and take it to your mechanic. If he insists that there's an inner seal, get a different mechanic.
weewilly #1522138 10/16/2023 7:09 PM
Ok, that's what I figured. He wasn't touching the diff. From what he had said. So do I need to get the 2 gaskets on the way that are on each end of the axle? What are these called if so. Thanks so much...again
weewilly #1522139 10/16/2023 7:22 PM
You might want to get the gasket at the axle flange if he's separating the drum from the axle (likely). Only 1 per side is needed, the one between the axle flange and deflector won't be needed as it's held on to the axle flange by the pressed in wheel studs. He will need to open the differential cover to get the axles pulled if you're replacing wheel bearings and seals. The spider shaft and block need to be removed and the axles pushed in to remove the "C" clip, then the axles can be pulled. Get a new gasket for the diff cover.
If he doesn't know that he needs to open the diff, then maybe you need another mechanic. ohwell
weewilly #1522144 10/16/2023 8:12 PM
Ok ordered a diff gasket this morning. Didn't know about drum gasket. At the end of the week I'm asking for an updated account of what is done and cost. Not afraid to tow back to storage if things are not adding up. I would be doing all myself but want to get the motor in, bearings, brakes, new radiator, starter, clutch kit and our local transmission shop is the best so that would be next if we can keep moving forward. I rented a hot water power washer and scrubbed the bottom clean. Used kroil many times on nuts/bolts and loosened all on brake lines. Pushed some new grease into everything that had a zerk to push out water and old grease.truck is super rust free for Iowa. Prepped well.
weewilly #1522145 10/16/2023 8:19 PM
Happen to know the bolt size on diff?
weewilly #1522156 10/16/2023 10:12 PM
Don't quote me, but I think the cover bolts are 1/2" hex head and maybe 5/16" dia coarse thread.
