0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I stopped on the way home to see if there was any progress on finding the reason I lost power to most of the functions, turn signals, radio, and horn but not headlights. He said because of the number of wires under there he could not determine what the problem was. He has a call into a friend to see if he can make a suggestion as to where to go. It runs and drives after JDL ran a bypass wire to a switch to shut the power off. Any suggestions? PLEASE.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | Ron, are you still running the stock amp meter?
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Nov 2021 Posts: 1,393 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,393 | Where was the jumper wire inserted? Assuming it was from the battery to the coil it definately indicates that the problem is in the wiring that provides power to the coil. Amp meter is a good place to start although if the headlights work I believe they are fed through the amp meter. My bet would be the ignition switch, he should be able to check for power to the switch and power to the coil coming out of the switch to isolate it. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | If your mechanic says he can't find an electrical problem in a 54 because there are too many wires, you need a new mechanic... | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Ron, is the wiring harness "stock" or aftermarket? If aftermarket we would need to have the wiring diagram/schematic. Thanks.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | It is a custom fuse box and wiring harness. I think all from Ronfrancis. There are as many fuses in use as a newer truck. Jordan wired a jumper from the battery to the ignition switch. I can use the ignition to start it but it will not turn it off. There is a switch on the e-brake handle that kills the power to the ignition switch. The weird thing about it is it just died while I was running along at 70 mph, JUST Quit no sputtering just quit as if I turned it off. The one place in town that could have diagnosed it closed this year. I knew the owner's daughter from German class in high school, in 1961. BTW they owned a 1961 Jag XKE from new and was said to have 400000 miles on it, yes 40000.
| | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | You definitely need a different spark chaser if he can't figure out something as simple as stovebolt wiring! Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I consider JDl very competent and he chased the problem on the side of the road and he did get to run and drive to his place then back home. He just maybe needs a light bulb to show him the way. I may take it home for a while, his shop is full of daily drivers. Mine will still drive but I have no turn signals.
| | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Custom wiring on a hot rod is really cool until it isn't. Especially if you are trying to have someone other than who installed it to troubleshoot it.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The shop where it was built closed after, retirement, but one of the guys who worked there is still around, I may see if he is available to check out, btw he is at another shop now.
| | | | | Joined: Nov 2021 Posts: 1,393 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,393 | You know a few things that may be helpful to identify the problem: bypassing the wiring to the ignition switch allows it to run; however, with the bypass in place the ignition switch does not disconnect the ignition to stop the engine; the e-brake switch kills power to the ignition; and the problem happened while driving.
The e-brake switch killing the ignition seems strange but unless the switch was somehow actuated while driving it seems unlikely to be the source of the problem.
The bypass to the ignition switch that allows the engine to run is promising but the fact that the switch does not shut off the engine indicates either the jumper bypassed the ignition switch (connected directly to the ignition) or there is a problem internal to the switch. Next step would be to confirm what the bypass is actually connected to on the ignition switch. If it is connected to the battery terminal look into a replacement ignition switch, if it connected to the ignition terminal, change it to the battery terminal to determine what changes. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | There's a considerable amount of wires under there. Picture a wiring harness from a late 90s grand marquis stuffed up under the dash.  The gist of the issue is he lost power to his ignition coil. If his fuse box was installed as labeled and my memory hasn't failed me in recent weeks, he lost power to coil, heater, turn signals somewhere before or inside the fuse box. I ran a hot wire to a toggle switch i mounted on the e brake handle to start/stop his engine to get him home. I don't envy the guy who is looking it over. Hope this clears up some things | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
| | | | | Joined: Dec 2020 Posts: 1,967 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,967 | Custom wiring on a hot rod is really cool until it isn't. Especially if you are trying to have someone other than who installed it to troubleshoot it. Good Luck!! Custom work to any of these old trucks is risky. In my experience, they do not like any new fancy gadgets. They speak a different language. If I was having troubles like that, I rip it all out and start over. Wiring these trucks kept original is not hard. Proof is, I`ve done it.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
