Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#1521507 10/12/2023 5:53 AM
Does anyone have an assembly manual picture of the Throwout arm spring for my 1953 GMC truck? Thanks in advance
Here's the figure for the clutch pedal return spring.
Thanks for the figue of the clutch pedal return spring. Is there another spring for the clutch fork?
No, There's a keeper spring inside the bell housing that holds the pivot ball, but otherwise, if not attached to the linkage, the fork just flops around.
buckaroo01,
Perhaps you are referring to that fork pivot ball retainer spring Kevin mentioned???
1st pic below is from one of the Chevy Master Parts Catalogs.
2nd pic if from the 1950 GMC parts catalog.
Both catalogs list that spring as GM# 838987, so same for GMC or Chevy.
~ Dan
1951 Chevy 3 window 3100
