5 members (PAUL Berardi, Bill Hanlon, Otto Skorzeny, moparguy, DaveV), 127 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
My Master Parts Book lists different part numbers for the '39 and '40 radiators. I know the dog houses are slightly different in 1939 and 1940. I haven't decided which styling I want to use yet IE the '39 or '40. US Radiator shows to have one for 38-40. Bowtie Bits also has a NOS 39 Harrison. Does anyone know if there is a difference between the original radiators that would cause fitment issues down the road?
Here is a link to the parts manual showing the different part numbers:
http://www.gmpartswiki.com/getpage?pageid=215449
~ Daniel Davidson
1939/1940 Chevrolet/GMC
Follow his Project Journal
Danielbolt,
A check of the earlier 1929-41 parts book https://chevy.oldcarmanualproject.com/parts/1929_41/41cp026.html shows the 1939 JC model radiator # 3112130 to be the same between the 2 books.
But the earlier book shows # 3113453 for the 1940 KC model radiator (looks like the later book shows a newer # 3117627).
Crazily, a quick web search for GM# 3113453 shows this radiator offered.
Not sure if you can take advantage of the offered item (not mine btw), but if nothing else you could capture screens shots of the pictures to use to help identify an original radiator.
NOTE: If you can't manage to snag that item, let me know so I can post that ad in the Other Online Sources forum so maybe another Bolter can snag it. wink
~ Dan
1951 Chevy 3 window 3100
I won't be able to grab it. I'm still not sure which doghouse I'm going to use but I am trying to find out if there is a dimensional difference or just what the difference would be in general.
~ Daniel Davidson
Thanks for the reply Daniel.
I will post that ad in the other forum later today some time.
Hopefully some fellow Bolters with '39 and/or '40 1/2Tons will chime in here on the original dimensions???
~ Dan
