Brrrr
place holder
0 members (), 166 guests, and 5 robots.
Topics128,271
Posts1,058,415
Members48,485
#1519658 09/29/2023 7:40 PM
I am doing a firewall mounted, power brake conversion on my 58 and as a side effect I have a bunch of spare/unneeded holes in the floor (old MC fill, brake light switch mounts, pedal hole, etc) that I want to fill.
I could weld them shut, but I don't want to do too permanent of a "fix" in case someone eventually wants to out this cab back to stock.
I am thinking about getting some of that foil backed butyl rubber mat and covering the whole floor as a sound/heat barrier. It is self-adhesive, so it would stick over the holes and seal them against moisture/dirt intrusion.
Any better suggestions?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
2 Offline
I have plugged holes with small metal patches with closed cell foam gasket on the outside patch against cab and a second patch or shape inside that bolts or screws the two together through the hole
This allows for ready removal if I want to modify it to run a wire or hose later and also doesn’t change the cab metal from stock
A double sided metal patch is stronger against debris and fire
And the gasket keeps it dust and water tight
This method is likely overkill for small holes and your time might be worth more than mine wink
-s
That is exactly what I do to "cover" extra holes. I do that because it is in the same vein as what the factory did with all of the unused factory holes on these trucks. They used an asphalt looking material on the inside.
-s
That seems like a good plan for the larger ones (like the MC fill). I might do the rubber cover over the whole thing, then cut it out of the bigger holes and put plugs like that in.
Thanks for the suggestions!
Similar to the above, I'm sure it would work fine without a cover, but personally for larger holes I usually make sheetmetal caps (and usually get fancy and play with the bead roller on larger ones), paint them and then screw or rivet them in before I cover em up. After that I have used the butyl backed sound deadening stuff and yes, it works fantastic. And does a good job on smaller holes. I do that as I figure dust/dirt/grime might work its way underneath the surrounding area and maybe cause other issues down the road, although... I'm probably worrying about nothing
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
Moderated by  ndkid275, Phak1
