| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Not me my 1954 3100 pickup. I never noticed before now, after the installation of a Pacer front end and a 1960s Impala steering column 30 years ago. I had new tires installed at the beginning of this month and if you had not heard I did not get far on my trip to KC. I am thinking maybe that rubber connector on the bottom of the steering shaft. Or maybe I should install a steering stabilizer. What say you all?
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2015 Posts: 11,051 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,051 | I would get the alignment checked first. Something may have worn in the front suspension, throwing alignment off. That could easily cause it to wander.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Not me my 1954 3100 pickup. Now, that's funny Ron.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Dec 2020 Posts: 1,960 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,960 |
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Sep 2009 Posts: 5,834 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,834 | Ron, If a "rag joint" was used to connect your Impala steering column to the Pacer steering (not sure what you have as I don't think I have ever seen a picture of your actual front suspension/steering details), that could be a possible source of the truck wandering down the road.  I would 2nd Kevin's suggestion to have the front suspension thoroughly checked for wear and alignment, especially if it hasn't been gone through since you had it built/installed. Of course, there might be a little wandering eye or wandering mind going on as you tool about your locale.  Just saying my friend - haha!  A steering stabilizer isn't going to help you out, at least at this point. A chauffeur with a stead driving hand may though.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | There is a small amount of loose feeling when you move the steering wheel. A little to the left or right without and feeling of connection. Very very small. Thanks all. Yes, Dan even at 80 I still like the ladies, even in my casket, I will still will be peering over the side, metaphysically, to see who is walking by.
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | We get complaints at work when we install new tires on school buses. The new rubber is much soften than the old tires, drivers always complain its all over the road. | | | | | Joined: Sep 2009 Posts: 5,834 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,834 | Ron, Only thing left to say on the "very very small" feeling of movement "left or right without any feeling of connection" is if it is concerning enough for your to worry about, get it checked out for your own peace of mind. Hope your day is good!  Dan PS - I moved this conversation to the Driveline forum as the best place to dicsuss "steering" questions.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Do you have a conventional steering box or a rack & pinion? There's a sector gear preload adjustment on a regular steering box that most alignment shops either don't know about, or choose not to do unless the customer insists on it. It can cause the wandering you're describing. PM me for details. Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | It is a rack and pinion, an AMC Pacer front suspension. While sitting behind the steering wheel you can induce a small movement left and right without the tires moving. I had new tires installed 2 days before I left for JDL and Missouri. It just seemed light and needed slight corrections. This is it.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | I'd start with an alignment. They should be able to tell if anything is worn and needs replaced. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I wish had thought of letting you drive it before I went back home. It is not like when you were a kid and steered back and forth pretending to drive. Just a small movement like it is not connected. It does not wander. When I left your place all I was concentrating on was getting home. In this town, there does not seem any place to take it and know what to do with it. Even though it has an AMC Pacer front suspension.
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Ron, if you took an AMC Pacer itself anywhere they wouldn't know what to do with it. If it isn't in their computer, they're clueless.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | My '03 Tacoma has a little of the same problem. If I am setting still, the steering wheel can move ever so slightly back and forth with no movement of the tires, it's kinda hard to explain what it feels like. I don't notice it while driving and doesn't seem to cause any problems, but come to a stop, I can wiggle the wheel and feel it. Feels like slop in the teeth, but only in the straight ahead position. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
