3 members (Peggy M, Cletus1950, Charles in CA), 134 guests, and 5 robots.
Topics128,106
Posts1,056,217
Members48,436
#1519013 09/25/2023 1:28 AM
On the accelerator pump shaft, on top of the metering rod bracket, should there be one or two springs?
Both the YFs I have, have two springs (inner/outer) but, I see some exploded views that only show one.
Also, some parts guys ( Mikes) only list one. Was there a design change?
How much if at all does it matter?
Thanks for any info you can give.
Tom
On the 2100S sheet I have from November 1953, the parts list shows part 61-431 Upper Pump Spring (outer) and 61-432 Upper Pump Spring (inner), in addition to 61-510 Pump Diaphragm Spring, which should be the big lower spring. This is the only 2100S sheet I have, so I can't speak on design changes/updates.
Maybe Carbking will chime in at some point with an expert opinion.
Moderator, Electrical Bay
There is a 1957 2100s document I got about 7 years ago...can't find it right now. It was an update to the 1953 document and I can't offhand remember but I suspect it may show any revision. Will keep looking. In the meantime, here is an image of the upper springs I removed from one to help me remember...2 springs. Carbking will know.
~ Jon
